Window wiper issue https://ausmini.com/forums/viewtopic.php?f=2&t=98760 |
Author: | Chris.Williams [ Mon Jul 08, 2019 4:55 am ] |
Post subject: | Window wiper issue |
Hi guys and girls I’ve been working on a friends 67 Cooper S (Aussie) they had a limp window wiper, I replaced this with new ones, problem is that they only work in a about a 10 degree arc on the window and won’t return to the resting point again. So they come on, go through a full sweep then start doing the part sweep thing, bit odd. Before I get ripping bits out I was hoping someone has had this issue and can point me to a possible cause. Sorry if I waffled a bit there ![]() |
Author: | drmini in aust [ Mon Jul 08, 2019 6:36 am ] |
Post subject: | Re: Window wiper issue |
Possibly the teeth in the wheelboxes are worn, if so you can pull the cable back then turn both spindles 180° and refit cable. So using unworn teeth. Unusual for both to go crook at exactly the same time though. |
Author: | Chris.Williams [ Mon Jul 08, 2019 9:16 am ] |
drmini in aust wrote: Possibly the teeth in the wheelboxes are worn, if so you can pull the cable back then turn both spindles 180° and refit cable. So using unworn teeth. Unusual for both to go crook at exactly the same time though. Ok, I’ll have a look into this. Thanks |
