Crank Pulley & Crankshaft Damper https://ausmini.com/forums/viewtopic.php?f=2&t=98704 |
Author: | cooperess [ Thu Jun 20, 2019 4:14 pm ] |
Post subject: | Crank Pulley & Crankshaft Damper |
Were the following parts used on the Mk2 Cooper S 1275 Motor? AEG454 & 12A367 |
Author: | winabbey [ Thu Jun 20, 2019 4:22 pm ] |
Post subject: | Re: Crank Pulley & Crankshaft Damper |
Yes. You can see the AEG454 stamp on the pulley I sent for balancing. viewtopic.php?f=3&t=98057&start=150#p1045712 |
Author: | Hinesy1275 [ Thu Jun 20, 2019 7:30 pm ] |
There were 3 x versions of inner pulley: 12A366, 88G305 and the AEG454. The former 2 were early iterations of the 454 and used on 997 & 998 Coopers. 12A 367 is the outer larger ring with rubber (harmonic) ring used in conjunction with all of the above variations - Cooper & S. |
