It is currently Fri Jul 11, 2025 12:03 am
PostPosted: Thu Jun 20, 2019 4:14 pm
Were the following parts used on the Mk2 Cooper S 1275 Motor?
AEG454 & 12A367
PostPosted: Thu Jun 20, 2019 4:22 pm
Yes. You can see the AEG454 stamp on the pulley I sent for balancing.
viewtopic.php?f=3&t=98057&start=150#p1045712
PostPosted: Thu Jun 20, 2019 7:30 pm
There were 3 x versions of inner pulley: 12A366, 88G305 and the AEG454. The former 2 were early iterations of the 454 and used on 997 & 998 Coopers.
12A 367 is the outer larger ring with rubber (harmonic) ring used in conjunction with all of the above variations - Cooper & S.
