It is currently Fri Jul 11, 2025 12:13 am
 Post subject: Tyres (again)
PostPosted: Mon Jun 17, 2019 4:59 pm
Ok I'm sure this is asked every few months but what tyres (165/70R10) are out there for the minis?
I've had a call around the local tyre shops and come up with Falkens or Yokohama, is their anything else?
Also what are people paying as well? So far I've found the yok's for $136-$155 and the Falkens are about $20 more expensive $145-$159.
 Post subject: Re: Tyres (again)
PostPosted: Mon Jun 17, 2019 5:22 pm
I posted about the new Blockley tyre a few months ago. Not sure if it's available here directly yet. Probably a lot more expensive than the two you mentioned. I think they now have a 165x10 version.
viewtopic.php?f=2&t=98354
https://www.blockleytyre.com/product/145r10
PostPosted: Mon Jun 17, 2019 8:21 pm
Those prices look expensive.
Minisport SA has the Falkens listed at $99 each and standard Yokos at $125 each.
Cost of freight, fitting and balance would be covered by the savings on the Falkens, which are good as a road tyre (depending on what performance you are after).
PostPosted: Tue Jun 18, 2019 6:09 pm
I drive pretty hard so I need good grip, I have used Falkens in the past and they didn't seem to last much longer than the others plus they were a bit lower on grip.
I ordered some Aoo8's this arvo @ $136 each fitted and balanced.
PostPosted: Wed Jun 19, 2019 5:53 am
Hi mate did you try miniworks they hace them in stock.
PostPosted: Wed Jun 19, 2019 8:45 pm
Do they make A008’s anymore? They were a good tyre.
PostPosted: Thu Jun 20, 2019 2:33 pm
Yes they do, Yokohama have spread rumours for years they are or will be NLA but when you stump up the $$$ they mysteriously appear.
I need a pair soon to replace my (edit) 10 year old ones.. ;)
On special for $125 + freight from Mini Sport SA. But I will get Sydney quotes from Bob Jane etc.
Last edited by drmini in aust on Thu Jun 20, 2019 5:53 pm, edited 1 time in total.
PostPosted: Thu Jun 20, 2019 4:30 pm
Hey Doc, what do you get charged for fitting and balancing?
PostPosted: Thu Jun 20, 2019 5:02 pm
it's $15 down here...
strong suggestion for you, ring Bob Jane in Albury and get a quote, it's been a couple of years but I paid ~$130 fitted and balanced. If you get a quote from Albury and go into another Bob Jane who want to charge more you can say "sharpen your pencil mate, another Bob Jane quoted me $x". They don't need to know that the other Bob Jane was 2000km away
PostPosted: Thu Jun 20, 2019 5:52 pm
I bought 2 a year or so ago from Bob Jane Blacktown, $138 ea fitted and balanced.
PostPosted: Fri Jun 21, 2019 4:29 pm
Around here fit & ballance is about $20 each. So for me there isn't much savings to be had by buying just the tyre and then fitting it locally.
