It is currently Fri Jul 11, 2025 3:31 am
 Post subject: What turbo
PostPosted: Sun Jun 09, 2019 10:23 pm
Now that the Garrett gt1548 is no longer avaliable what other turbos are a good size for a 1330?
 Post subject: Re: What turbo
PostPosted: Mon Jun 10, 2019 1:21 pm
Milatsmadmini
GT17
PostPosted: Mon Jun 10, 2019 5:59 pm
I run a old T2 off a Nissan exa for years and it made 120 atw with no problem.
PostPosted: Tue Jun 11, 2019 3:22 pm
The Garrett GT20 is pretty similar to the GT15 - the low airflow side of the compression map is near identical, but it gives you more room on the high airflow side. If the engine is worked I would expect it to work well.
PostPosted: Tue Jun 11, 2019 6:21 pm
Gt1752 is the new turbo of choice
