https://ausmini.com/forums/
Diagonal Tie Rod Washer position
https://ausmini.com/forums/viewtopic.php?f=2&t=98653
Author:  GuamMini [ Thu Jun 06, 2019 8:39 am ]
Post subject:  Diagonal Tie Rod Washer position
I am replacing my Diagonal Tie Rod bushings and would like to know how does the washer on the side where the nut goes is facing? it is not a flat washer but a washer the is curved or like a bowl shape. Which side is facing the bushing the closed or open side of the washer. Sorry this is the best I could explain it.
I hope some of this picture helps.
This looks like there are two washers a flat one and a curved one?
Author:  cgo [ Thu Jun 06, 2019 11:40 am ]
Post subject:  Re: Diagonal Tie Rod Washer position
20 is cup washer, concave face to bush
21 is flat washer
Diagram only shows one bush of the two per side
Author:  GuamMini [ Thu Jun 06, 2019 11:54 am ]
21 is flat washer
Thank you no wonder they also sell the flat one, thanks
Author:  1071 S [ Thu Jun 06, 2019 6:50 pm ]
Looks like you have the "correct" pairing of one poly bush with one rubber version. Don't forget to put the poly item at the front....
Cheers, Ian
