It is currently Fri Jul 11, 2025 12:14 am
 Post subject: Cold Morning Starts
PostPosted: Fri May 31, 2019 9:06 am
Hi All,
Winter is here in Sydney and my mini has become much harder to start up in the mornings.
I am just wondering if there are any tips/tricks for getting it to start during the winter?
I have just recently replaced the battery but am worried about killing it with the amount of cranking I need to get the engine started.
Thanks
 Post subject: Re: Cold Morning Starts
PostPosted: Fri May 31, 2019 9:25 am
Tune up the ignition system... clean points, nice clean dizzy cap, new leads, quality plugs, choke that operates properly. There are up and down sides of electronic ignition but the hotter spark can help.
Standard Minis in good trim will generally start quite easily.
Back in the day ...before we could really afford much in the way of modifications :) it was a point go honour to have you Mini start on the first flick of the key....
Cheers, Ian
PostPosted: Fri May 31, 2019 9:39 am
If the carb is SU, check that the choke cable actually pulls the jet down to richen the starting mix. The first part of the cable movement only increases the idle speed and you can't always feel the difference when operating the choke cable.
I have heard that petrol was once made in "summer" and "winter" blends with winter having more volatile ingredients to help carburettor motors start easier, and now that most cars are fuel-injected, that ingredient is no longer used.
PostPosted: Fri May 31, 2019 11:22 am
Mine starts up really well with the Dellorto and the choke on, even this morning :D . The Weber/Dellorto have an accelerator pump which helps richen it up during starting too.
Do you have a mechanical or electric fuel pump? Are you trying to start it with the clutch in or brakes on?
Also fit the biggest & highest CCA battery that will fit. Mine is a Century 58EB MF 560CCA. (I would have swapped the terminal direction, but there wasn't enough length on the positive end to stretch it over)
A kill switch can also help keep the battery from draining while sitting.
PostPosted: Fri May 31, 2019 5:56 pm
ben23f wrote:
Hi All,
Thanks
Winter in Sydney?
Drive the car about 300Km South West, stay overnight, come out in the morning to the real cold...then threaten to leave it there if it won't start :!: :lol:
PostPosted: Mon Jun 24, 2019 8:10 pm
Make sure your choke is properly set up , SU's like full choke .
PostPosted: Sun Jun 30, 2019 6:33 pm
This was recently the problem on mine. The chokes had seized and weren't pulling the jet down. Once freed up it starts beautifully.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
