https://ausmini.com/forums/
Primary Gear.
https://ausmini.com/forums/viewtopic.php?f=2&t=98612
Author:  stewartrjh [ Sat May 25, 2019 10:17 pm ]
Post subject:  Primary Gear.
Can anyone tell me what a 22A 79 Primary gear fits ?
Interested in it fitting an 1100 engine, from what I see it should be a 22A1493 which should fit 850, 998 and 1098cc.
Thanks
Stewart.
Author:  TOZOOM [ Sun May 26, 2019 7:51 am ]
Post subject:  Re: Primary Gear.
Hi the gear that you have mentioned is not for a small bore eng. unsure what that gear fits as its not a manual type or a auto type.
Author:  Bill B [ Sun May 26, 2019 10:56 am ]
According to ebay, 22A79 is the primary gear for early 850 with oil feed to bushes. I don't know if it can be run dry like the later primary gears.
Author:  drmini in aust [ Sun May 26, 2019 7:31 pm ]
If so it won't fit your crank, the oil fed 850 crank nose is 1-3/8" not 1-1/2" like all 998 and 1098.
If run dry it would seize, its bushes need oil.
Author:  stewartrjh [ Mon May 27, 2019 8:11 pm ]
Ah so very early 850 then.
Thanks for the info, not what I could use then.
Stewart.
Author:  drmini in aust [ Mon May 27, 2019 10:23 pm ]
Stewart.
Plenty of good S/H 998/1098 A series primary gears about. Common as.
