https://ausmini.com/forums/
Romac harmonic balancer
https://ausmini.com/forums/viewtopic.php?f=2&t=98591
Author:  Clownman [ Mon May 20, 2019 8:59 pm ]
Post subject:  Romac harmonic balancer
Apologies if allready covered, if I purchase a Romac harmonic balancer I'd assume I'd purchase a neutral balanced one as the a series engine is internally balanced? Secondly, Vizard says in the absence of an expensive viscous type damper, using one on the heavier side is recommended! Hence using a lighter Romac option consisting of metal/alloy would be against Vizard's re recommendation? Thanks
Author:  simon k [ Tue May 21, 2019 6:20 pm ]
Post subject:  Re: Romac harmonic balancer
yes, neutral balance... assuming that means it isn't weighted one way or the other. Balancing for our engines is done for each piece individually
weight depends on the engine? 1275 and 1100 had a heavy one, little engines just had a light pulley
Author:  drmini in aust [ Wed May 22, 2019 8:46 am ]
Some folks here are running a blower with a crank pulley (no damper) due to lack of room. The jury is still out here on this causing failure on a road car.
Author:  Clownman [ Wed May 22, 2019 3:53 pm ]
Thanks Chaps, 1275 non-s +60, lightened flywheel/pressure plate/conrods/, roller rockers, 45 dcoe, etc. Guy from Nornda Automotive who make Romac, said neutral also. I mentioned Vizard's recommendation of heavier balancer but he said they sell more of the lighter steel/alloy!
Any further suggestions.
Author:  awdmoke [ Thu May 23, 2019 11:19 am ]
I have had a Romac light alloy damper for years, and that is on my 1430cc stroker.
Still going strong.
