https://ausmini.com/forums/
Cleaning ROH wheels
https://ausmini.com/forums/viewtopic.php?f=2&t=98584
Author:  slabber [ Sat May 18, 2019 2:36 pm ]
Post subject:  Cleaning ROH wheels
Any ideas on the best/easiest way to clean these up?
Author:  Bill B [ Sat May 18, 2019 4:53 pm ]
Post subject:  Re: Cleaning ROH wheels
If you want a good job, the tyres, wheel nuts and caps need to be off the wheels.
Otherwise, remove wheel one at a time, remove centre cap; Septone "Al-brite" is an acid that will clean off the white aluminium oxide. Use a plastic dishwashing brush to apply and keep wet until it looks better; and rinse off. The diamond-cut outer steps from the tyre bead back to the knobs (spokes) can be cleaned up with wet/dry 320 grit paper (or finer grade) and then polished with Autosol.
With the tyre off, gutter scrapes can be filed out completely.
Author:  s-c1293 [ Sat May 18, 2019 9:23 pm ]
You could get them Hydroblasted, It'll bring them up like new.
My wheels were like yours and turned out like this.
Author:  Scoop [ Sat May 18, 2019 10:19 pm ]
Going off winabbey's gearbox components I would hydroblast them!
Author:  drmini in aust [ Sun May 19, 2019 10:17 am ]
+1 for hydroblasting.
But I hand sanded the spokes on mine. Then I put them in the big lathe at work, machined the gutter rash, then wet sanded with 400, 800 and 1200 paper.
After masking I painted the spokes with septone etch primer. And gloss black acrylic cans.
Finally polished with mother's mag wheel polish.
Author:  slabber [ Tue May 21, 2019 8:57 am ]
Cheers, thank you
