https://ausmini.com/forums/
Clubman GT pinchweld
https://ausmini.com/forums/viewtopic.php?f=2&t=98569
Author:  red clubbie [ Wed May 15, 2019 5:39 pm ]
Post subject:  Clubman GT pinchweld
Hi Guys,
I mentioned in another post, that I going to investigate if I could dye the black pinchweld that is currently available.
I had the dye colour matched to the original pinchweld.
I had some Leatherique Prepping Agent left over from a previous project, so I wiped it on and then did three coats of dye...
It's a tedious job, but it's turning out OK.....
Geoff.
Author:  p7676 [ Wed May 15, 2019 8:01 pm ]
Post subject:  Re: Clubman GT pinchweld
The pinch weld is the welded flanges around the door, you have a door seal .The flange cover can easily be painted with 2 pac primer and colour.Also Bunnings sell epoxy spray paint suitable for vinyl the paint works well. They have a colour about the same as your sample. You can also buy a clear plastic primer then colour on top excellent adhesion. Spray cans.
Allen
Author:  red clubbie [ Wed May 15, 2019 9:24 pm ]
Allen
Your comments are noted, but I have never had a problem with using Leatherique products.
More than one way to skin a cat.... :wink: :wink: :wink:
Geoff.
