It is currently Sat Jul 12, 2025 10:56 am
PostPosted: Thu May 02, 2019 9:44 am
Hi Guy's,
We've come into a slight problem in regards to fitting our speedo cable onto the back of the gauge.
The engine is fitted with a 5" long inlet manifold with a 45 DCOE Weber (with 16mm Ram Tubes, including mesh cover's...), however when trying to fit the speedo cable, the mesh cover interferes with the cable, which has the ability to either break the back of the gauge or the cable in the foreseeable future.
Now, we've been told (and researched...) that an angle speedo drive from either a Rover 3500 or an early model Range Rover may suit this application?
Any help or insight would be greatly appreciated!
Thank you...
PostPosted: Thu May 02, 2019 10:44 am
Smiths made a right angle drive adapter with the correct cable thread and size that might help. Problem is they are difficult to find nowadays and can be expensive when you do find one.
https://minikingdomonline.com.au/produc ... e-adapter/
PostPosted: Thu May 02, 2019 10:47 am
Thanks winabbey!
Your a 'Champion' and very much appreciated!
TOY444
PostPosted: Thu May 02, 2019 10:51 am
I found one at the wreckers on a Rover
I had taken a mini speedo to check the thread was OK and it was all good. The part number is BH 2410/10. It set me back $15
Some photos fitted:
PostPosted: Thu May 02, 2019 10:55 am
Thanks timmy201!
Great mate, it's much appreciated!
TOY444
PostPosted: Thu May 02, 2019 8:03 pm
After reading Timmy's post a while back I kept my eye on eBay and Gumtree, as I was looking for a solution to the same problem. I found a guy on Gummie wrecking a Rover P6 (3500 v8) and he sold me the speedo angle drive. I had to pay $60 including postage but I'm still happy - hey I didn't have to spend a day wrestling spiders and rats in a wrecking yard!
Mine is a Smiths BG 2410 just like in Winnabey's pictures - and it looks the same as the BH model that Timmy found. I can confirm that it fits and works a treat. Now I can fit my 40 DCOE and have a working speedo.
PostPosted: Fri May 03, 2019 12:12 am
If space is an issue (well, MORE of an issue! :lol: ) then there is also a lower profile version that goes right up against the back of the speedo case. I believe they were used on some MGB's, Range Rovers, etc. They pop up on ebay occasionally and range from cheap to ridiculous. I got one last year for about $40 I think.
They are also available from some on-line english parts vendors. There are several part numbers they carry, but I think it usually is because there are different shaped plates to engage a locating peg on the back of the speedo case for fixing the angle the cable runs at. All I have taken notice of are 1:1 ratio.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Fri May 03, 2019 1:18 pm
And another one :lol:
Mine came from a 1960's Jag. $30 from a wreckers about 5 years ago...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon May 06, 2019 6:45 pm
Hi Guy's,
Thanks again to all of you, you've all been a great source of information and it's very much appreciated!
