https://ausmini.com/forums/
Master cylinders
https://ausmini.com/forums/viewtopic.php?f=2&t=98493
Page 1 of 2
Author:  glenndunn [ Tue Apr 23, 2019 1:45 pm ]
Post subject:  Master cylinders
I have a 67 mk1 Cooper S and these are the master cylinders I'm pretty sure the tin brake master is correct but not sure about the plastic tank cluch master
Can someone enlighten me
Thanks
Glenn
Author:  Bubbacluby [ Tue Apr 23, 2019 1:57 pm ]
Post subject:  Re: Master cylinders
Plastic master cylinder is incorrect. They came in around 1970/1971
Sent from my SM-N960F using Tapatalk
Author:  AJ [ Tue Apr 23, 2019 6:07 pm ]
For a 67 model it would have had tin brake and clutch master cylinders originally
Author:  gtogreen1969 [ Tue Apr 23, 2019 8:43 pm ]
Here is the engine bay for a 1967 S. If your car is pre YKG2S2 3792 it would have also been fitted with the plastic extensions. The brake master should be Lockheed .7" and have a tall reservoir. The clutch master should be a Lockheed .75" and have a shorter reservoir.
Author:  simonw [ Tue Apr 23, 2019 9:49 pm ]
I had the same question today !
My 67 deluxe came with the same setup as yours , so obviously its been changed out along the way too.
My plastic tank is PBR and must be for the clutch ....cant remember which side I pulled it off !
This is what happens to the tin after 50 years :(
Author:  glenndunn [ Wed Apr 24, 2019 8:00 am ]
Mine is 3688 I have never seen the plastic extensions befiore, never seen them is any of the mini sellers catalogues.
Where would I be able to get them
Author:  gtogreen1969 [ Wed Apr 24, 2019 8:04 am ]
Here is one example https://minikingdomonline.com.au/produc ... with-seal/
Author:  timmy201 [ Wed Apr 24, 2019 8:19 am ]
I bought a new one recently, and found it was a slightly different shape to the older style ones. The old ones were parallel the whole way up, and the new one I bought was thinner above the thread. E.g.
Author:  Bill B [ Wed Apr 24, 2019 10:22 am ]
That is about right.
John Sneddon's book lists the change from tin tanks to plastic as August 1969, in early Mk2 production. That suggests that 300+ Mk2s had tin tanks.
Author:  ianscampbell [ Sat Apr 27, 2019 2:13 pm ]
My Mk2, 1969 car 940, had the tall plastic clutch master cylinder & the original Mk1 type tin brake master cylinder, which I believe was correct for the era?
Author:  winabbey [ Sat Apr 27, 2019 2:30 pm ]
See this Service Liaison Letter.
Author:  gtogreen1969 [ Sat Apr 27, 2019 3:08 pm ]
This may help date the clutch master cylinder change. Car 839 was fitted with tin master cylinders.
Author:  crisonic [ Sun Apr 28, 2019 10:38 am ]
Many thanks for the Service Liasion Letter
It makes reference to "... and spacers are used to obtain pedal height" Can anyone tell me where these spaces are located and what thickness they are.
Author:  simonw [ Sun Apr 28, 2019 11:29 am ]
This suggests that my plastic reservoir replacement is inappropriate as my threads on the pedal box will be too short ... let me go measure them. Didn’t know there were 2 types of pedal boxes
Author:  cgo [ Sun Apr 28, 2019 1:13 pm ]
These 2 spacers came with a car I'm rebuilding. They are 1/16" or 1.6mm thick. Both master cylinders are the plastic reservoir type and spacers are placed between cylinder body and the pedal box mounting point. Have no idea if they are original. I'm sure an expert will set this straight.
I also have a car with a metal brake master and a plastic reservoir clutch master which has metal spacer.
