It is currently Fri Jul 11, 2025 6:50 am
 Post subject: Mini Cooper Interior
PostPosted: Wed Apr 17, 2019 7:43 pm
I am trying to locate a supply of suitable material to retrim the interior on my 997 Cooper, 1963 model. I believe the colour needed is Tartan Red but this may not be correct,
Has anyone else found a suitable supply of a red material for the vintage of Mini?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
 Post subject: Re: Mini Cooper Interior
PostPosted: Wed Apr 17, 2019 8:21 pm
There is 2 different types of vinyl used, door trims dash and back of the front front seats it looks like it has been sandblast texture a cheaper vinyl inthe day and the front of the seats where you sit with the pleats is a smooth grain nicer looking vinyl
PostPosted: Thu Apr 18, 2019 4:40 pm
Maybe Bunnings could match the colour and you could paint some white canvas ? just a thought
PostPosted: Thu Apr 18, 2019 4:54 pm
Your local motor trimmer should be able to show you what is currently available from the main wholesalers. There is colour and there is grain (or pattern, if you prefer), both need to be right.
I couldn't get a right match for the green I wanted so I selected the faintest pattern, and the local vinyl colourer matched the colour and re-coloured the vinyl.
PostPosted: Thu Apr 18, 2019 6:15 pm
How did you go with grain though?
PostPosted: Thu Apr 18, 2019 6:21 pm
The faint pattern used on pieces where new vinyl was required are not able to be clearly "eyeballed" and no-one has noticed the replacement pieces. It is a better solution than trying to use a more distinct pattern which would be all too obvious.
Users browsing this forum: Bing [Bot] and 97 guests
