https://ausmini.com/forums/
Key barrel set
https://ausmini.com/forums/viewtopic.php?f=2&t=98460
Author:  Gambo [ Tue Apr 16, 2019 9:33 am ]
Post subject:  Key barrel set
Does anyone know if these will fit the Aussie wind up window doors? Mine are buggered....
http://www.minispares.com/product/Classic/27H9634.aspx
Alternatively, is there any way to repair them. The little nub on the end that turns the locking pin has worn/broken off.
Author:  drmini in aust [ Tue Apr 16, 2019 1:23 pm ]
Post subject:  Re: Key barrel set
I think John Smidt told me once that the boot lock tumbler can be modified to fit Oz windup door locks.
The UK door tumblers apparently don't fit.
Edit
Yes you can repair the little pin thing. I fixed a boot lock one by carefully drilling it out then pressing in a pin made from a bit of nickel bronze welding rod. I think it was 2.4 or 2.5mm diameter. I Loctited it as well.
Author:  Gambo [ Tue Apr 16, 2019 1:27 pm ]
thanks Doc.
Going to see if I can fix mine, otherwise i'll try the boot lock method.
Author:  cgo [ Tue Apr 16, 2019 2:50 pm ]
As Doc said, repairable. Broke pin off due to brute force and ignorance. Drilled hole in barrel, tapped thread and used small screw to repair. Loctited and cut off head, still operational.
Author:  Gambo [ Tue Apr 16, 2019 2:58 pm ]
You absolute champion! Exactly what I need to do to get mine fixed!
