It is currently Sat Jul 12, 2025 11:15 am
 Post subject: mk 2 cs speedo
PostPosted: Wed Apr 10, 2019 5:12 pm
I have been told today my speedo is from a mk 1 cs.Can you still buy a mk2 speedo and maybe some one would like mine it works well.
Allen TY
 Post subject: Re: mk 2 cs speedo
PostPosted: Wed Apr 10, 2019 7:09 pm
Allen TY
The MK2 S speedo is rare. You may only see one or two per year listed on Gumtree, Facebook or Ebay. You could try and find a second hand one by ringing around the various Mini Shops or Howards or place a few wanted adds hoping someone has a spare. The speedo you are looking for is 54M2-1/12. Here is an example
PostPosted: Sat Apr 13, 2019 4:51 pm
David Walker had listed one on Ebay. https://www.ebay.com.au/itm/Morris-Coop ... 7fbc2cce3d
PostPosted: Sat Apr 13, 2019 5:06 pm
Now sold.
PostPosted: Sat Apr 13, 2019 6:06 pm
There will probably be a few more come out of the woodwork if sellers see the price it went for.
PostPosted: Sun Apr 14, 2019 10:16 am
Crikey I thought I could get one for $100 as most of them have to be repaired,
PostPosted: Sun Apr 14, 2019 11:52 am
Realistically multiply that by 10 for a restored one.
1960 Morris Mini Minor
PostPosted: Sun Apr 14, 2019 9:56 pm
gtogreen1969 wrote:
Allen TY
Silly question: is there a difference between Mk1 and Mk2 gauges - speedo, oil and temp, regarding whether the face is black or slightly grey?
(trying to avoid a "shades of Grey" reference here).
PostPosted: Sun Apr 14, 2019 10:28 pm
Apart from the Black and Grey background - The MK1 temp guage has a white scale marked C,N,H with a black mark at the C end and a red mark at the H end. There are 6 dots at different intervals under the scale and "Made in UK" at the bottom of the guage.
The MK2 has a plain white scale marked C & H with ramps at each end.
Apart from the Black and Grey background - The oil guages are similar except the MK1 has "Made in UK" at the bottom of the guage.
PostPosted: Mon Apr 15, 2019 8:30 am
It should be pointed out that the Mk I gauge above is either an Aus gauge or a later Mk I.
The original Mk I speedos have a scale that stops at 120....much like the MK II version.
Cheers, Ian
PostPosted: Mon Apr 15, 2019 8:41 am
If that's the case...then the picture above shows a MKI speedo in a MKII binnacle???
PostPosted: Mon Apr 15, 2019 9:29 am
IIRC, the original 1071 S had a speedo that went to 120MPH without the extra marks to 130MPH.
RonR
68 build Mk1 Cooper S
PostPosted: Mon Apr 15, 2019 9:48 am
I believe the Comet Grey faced ones came in with the MK II Series Minis and were made in Australia. This drawing showing the oil pressure gauge for YDO5 II would be the Mini K I reckon.
PostPosted: Mon Apr 15, 2019 5:27 pm
You made me go and check....
The original S speedo is different from either of the above.... and is somewhat of a combination of both. Basically, its looks like the Mk I shown above but with the final tick on the scale centred under the 2 of 120, without the 2 orange jewels at 3 and 9 o’clock, with a green jewel at 12 o’clock - where it reads 60 with the number 60 being much smaller so it fits under the jewel. Also, as early Ss came with 3.76 diffs (and 7000 redlines) the change marks are at 30, 50 and 70.
So, if you have an Oz car, looks like you’re going to need an Oz speedo....
Cheers, Ian
PostPosted: Mon Apr 15, 2019 5:47 pm
Cheers, Ian
My info was for the 1275cc Aussie Mk1 S (YKG2S2) and Aussie Mk2 S (YG2S4)
