1098 primary gear end float https://ausmini.com/forums/viewtopic.php?f=2&t=98427 |
Author: | simonw [ Thu Apr 04, 2019 3:04 pm ] |
Post subject: | 1098 primary gear end float |
Hi folks Have measured up the current end float at .28mm , I think that’s 11 thou. Is typical about 5? Would you recommend I replace the brass spacer ? Sent from my iPhone using Tapatalk |
Author: | cgo [ Thu Apr 04, 2019 3:27 pm ] |
Post subject: | Re: 1098 primary gear end float |
Simon, Vizard in "Modify your Mini" says endfloat should be between 0.0035" and 0.0065", aim for lowest limit in the interest of minimum gear noise. Matt Read sells spacers of varying thickness so you can set the correct clearance. Also check the condition of the outer thrust washer and the "C" ring, as they are prone to wear which increases endfloat. Clive |
Author: | simonw [ Thu Apr 04, 2019 3:30 pm ] |
Thanks Clive I’ll look into this . I just remembered I also have your flywheel puller still ! Sent from my iPhone using Tapatalk |
