Compression Ratio - how high on 98 pump fuel? https://ausmini.com/forums/viewtopic.php?f=2&t=98424 |
Author: | IndigoBlueCooperS [ Wed Apr 03, 2019 5:08 pm ] |
Post subject: | Compression Ratio - how high on 98 pump fuel? |
What compression ratio can you run on normal 98 pump fuel? I typically run 11.5:1 with a street cam (RE83) on 98 with no problems. Is just over 12:1 a tad high with a similar street cam? Engine is 1310, the head has a slight skim and the block has been decked a bit (piston protrudes about 5 thou) Pistons are 6 cc dished. Measuring volumes and doing the calcs gives me 12.1:1 which sounds about right to me. Markings on the cam are a bit vauge but look like K?MD 276B. No idea what this is but was told a street cam?? So, is 12.1:1 too high for 98 pump fuel? |
Author: | 1071 S [ Wed Apr 03, 2019 5:11 pm ] |
Post subject: | Re: Compression Ratio - how high on 98 pump fuel? |
Its not really as simple as that... I found 10.5 was too much for my engine with a Kent 286 cam... Cheers, Ian |
Author: | SlipperyGypsy [ Wed Apr 03, 2019 5:35 pm ] |
I have 10-1 compression, no idea what cam should i be running 98? |
Author: | deluxe67 [ Wed Apr 03, 2019 6:40 pm ] |
I have 11:1 compression ratio and use 98 but can get away with lower octane fuel. I think it depends s bit on the cam's characteristics (overlap) and of course what advance curve you are using. I didn't have a problem using Indonesian fuel either though I did carry octane booster if needed. |
Author: | John Sneddon [ Wed Apr 03, 2019 7:47 pm ] |
When I was building my Cooper S engine the people I was working with made it quite clear not to take the compression ratio over 10:1 as this would result in an engine which would not be pleasant to drive in traffic. This engine is running at + 0.060", ported and polished AEG163 head, 1.3 roller tipped rockers, Mini Spares fast road cam which is very similar to Russell RE13, LCB extractors and electronic ignition and while slightly lumpy, is quite driveable in traffic. I am currently doing the engine for my 997 Cooper and the same criteria is being adopted. |
Author: | drmini in aust [ Wed Apr 03, 2019 8:40 pm ] |
I am running 11.0:1 on 98 with an RE282 cam and 1.5 rockers. When I had a Camtech VP3 (619) cam in it and flat top pistons I found 12:1 was too high. So for a while I ran 2x BK450 head gaskets. The more cam duration you have the higher you can go in C/R within limits. I think 12:1 is pushing it on a road car. |
Author: | IndigoBlueCooperS [ Wed Apr 03, 2019 9:07 pm ] |
Thanks Guys, I have done a bit more checking and come up with the same conclusions - 12:1 is too high. I will aim for between 10 and 10.5. Will probably do this by taking a bit (50 thou) of the top of the pistons (they currently protrude above the block by 5 thou). This is once I check the pistons have enough meat, otherwise I will attack the head. |
Author: | cgo [ Wed Apr 03, 2019 9:48 pm ] |
A engine, for road use, I have been working on has a calculated CR of over 11:1. Have purchased an 80 thou thick Cometic head gasket to get CR down to 9.5:1. Hope it's a solution, gasket wasn't cheap but cheaper than having head reworked. |
Author: | IndigoBlueCooperS [ Thu Apr 04, 2019 10:08 pm ] |
Hi cgo, thanks for your comment. The 2mm head gasket may be an option for me. I will look at this if I can't get the pistons machined. |
Author: | Toy444 [ Thu May 02, 2019 5:56 pm ] |
We're running 10.6:1 with a SW8 Swiftune Camshaft and No:13 advance curve on a CSI Distrubutor on 98 Octane with no detonation at all. |
