https://ausmini.com/forums/
Hydrolastic Pressure
https://ausmini.com/forums/viewtopic.php?f=2&t=98408
Author:  IndigoBlueCooperS [ Sat Mar 30, 2019 11:25 am ]
Post subject:  Hydrolastic Pressure
Hi All,
What is a good pressure for when the car is off the ground?
That is, a normal pressure of 275 PSI on the ground is equivalent to ??? with all four wheels of the ground?
I want to set it so that I have some chance of it being around the mark when I lower the car to the ground.
That is, I will have some chance of a reasonable ride height which will obviously need some fine tuning once settled.
Thanks
Author:  Bill B [ Sat Mar 30, 2019 2:41 pm ]
Post subject:  Re: Hydrolastic Pressure
Can't remember actual numbers but guess at around 230-240psi. It isn't a huge difference.
Author:  9YaTaH [ Sun Mar 31, 2019 8:33 am ]
The technique is to pump to 300 PSI (even a little over)...drive it around for a couple of days till it all settles down...then adjust ride height to your liking...
[Edit: usually after disassembly/reassembly]
