It is currently Sat Jul 12, 2025 3:32 pm
 Post subject: Hydrolastic Pressure
PostPosted: Sat Mar 30, 2019 11:25 am
Hi All,
What is a good pressure for when the car is off the ground?
That is, a normal pressure of 275 PSI on the ground is equivalent to ??? with all four wheels of the ground?
I want to set it so that I have some chance of it being around the mark when I lower the car to the ground.
That is, I will have some chance of a reasonable ride height which will obviously need some fine tuning once settled.
Thanks
 Post subject: Re: Hydrolastic Pressure
PostPosted: Sat Mar 30, 2019 2:41 pm
Can't remember actual numbers but guess at around 230-240psi. It isn't a huge difference.
PostPosted: Sun Mar 31, 2019 8:33 am
The technique is to pump to 300 PSI (even a little over)...drive it around for a couple of days till it all settles down...then adjust ride height to your liking...
[Edit: usually after disassembly/reassembly]
