It is currently Sat Jul 12, 2025 11:08 am
 Post subject: Fuel tank grommet
PostPosted: Wed Mar 27, 2019 12:31 pm
This rubber is only 4 years old :( Remarkably it's also water soluble. Does anybody supply decent ones?
Do I need to remove the tank to replace it? I forget..
Thanks.
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
 Post subject: Re: Fuel tank grommet
PostPosted: Wed Mar 27, 2019 6:10 pm
Unfortunately the ones you buy new all perish in no time. Mine are doing the same and they are only 4 years old too.
"Let us remove your "SHORTS"
PostPosted: Wed Mar 27, 2019 7:07 pm
More Chinese crap?
PostPosted: Wed Mar 27, 2019 9:07 pm
yep same problem here chinese crap
PostPosted: Wed Mar 27, 2019 9:12 pm
Lower control arm bushes. Upper control arm bump stops, PCV valve diaphragms etc etc.
If any supplier can guarantee their product will last, I would like to know.
PostPosted: Thu Mar 28, 2019 11:11 am
I bought mine from MKO. They had 2 different ones in stock, I bought the “good one”. They have a different profile to the one in the top picture. It’s lasted very well so far
PostPosted: Thu Mar 28, 2019 3:00 pm
Same problem - this is the 2nd grommet fitted to the car while it was being REBUILT!
The fuel tank has to be at least partly removed so that the neck is away from the hole to allow the grommet to be fitted. I think (I am hoping) the petrol outlet does not have to be removed (also not easy as everything is a tight fit).
I have bought 2 new grommets from Scott's Old Auto in Melbourne. They are about $20 each - dearer than most junk ones. They look a lot like Timmy201's photo.
Have not fitted either one yet so I am not able to confirm their quality but can confirm they have not started to perish yet while they have been sitting on my desk for the past 4 months!
PostPosted: Thu Mar 28, 2019 3:18 pm
Memo to suppliers-
It matters not how cheap things are, if they don't work, fit or last. :evil:
PostPosted: Thu Mar 28, 2019 5:13 pm
Memo to suppliers-
I agree. It's very annoying to be sold inferior products, especially if the seller knows it is poor quality.
However, the supplier needs to be aware when a product is not up to spec. If a customer just throws the old one in the bin and buys elsewhere they won't know and they'll keep selling it as being suitable.
PostPosted: Fri Mar 29, 2019 4:34 am
I have the same ones as timmy201 and they have been in my car for about 15 years and have not changed since they have been fitted. You can still buy them from the rubber place in penrith ill find out there name.
PostPosted: Fri Mar 29, 2019 8:49 pm
Please be advised that there is now available a genuine 14A7057.
Quality is excellent.
