heater tap ,metal rocker cover 1970 cs https://ausmini.com/forums/viewtopic.php?f=2&t=98390 |
Author: | p7676 [ Sat Mar 23, 2019 5:56 pm ] |
Post subject: | heater tap ,metal rocker cover 1970 cs |
The heater tap lasted 4 weeks before it fell apart are there any good ones , does the cs rocker cover have a metal tube and rubber hose that connect to the air cleaner ? probably for crankcase ventilation . I have just noticed my cover does not have a metal tube, If I fitted a tube would there be a baffle under the tube to prevent oil in tube ? Also will the car go better with the ventilation ? Cant find a replacement at MK or MS. Allen TY |
Author: | gtogreen1969 [ Sat Mar 23, 2019 6:12 pm ] |
Post subject: | Re: heater tap ,metal rocker cover 1970 cs |
The heater tap leak sounds like most of the repro parts these days - pot luck. Return it and try again with another or try and find a NOS heater tap. Cooper S rocker covers do not have a vent pipe. The system needs to be closed to allow the PCV to work correctly. The oil filler cap has a small filter and allows air into the rocker cover when needed. This is the rocker cover used on a 1970 MK2 S. Attachment: 1970 MK2 S rocker cover.jpg
Author: | slacko [ Sat Mar 23, 2019 7:53 pm ] |
Author: | p7676 [ Sat Mar 23, 2019 8:54 pm ] |
TY for the info Gotto your a Legend. |
