It is currently Sat Jul 12, 2025 1:46 pm
 Post subject: Cobra seat internals
PostPosted: Sat Mar 23, 2019 5:12 pm
The topic of aftermarket seats has appeared sometimes.
I have been using a pair of Cobra seats for several years; over time the cushion has slowly collapsed. I have removed the base piece which has been crumbling and needs to be repadded with new foam.
The main seat construction is round and square tube; the base is a rubber diaphragm, like most standard mini seats, but only attached at the sides and not at the back where the main weight load "sits".
At the back, there is only a high tensile rod to take the occupant's weight. See photo 1.
Result is the moulded foam cushion is cut open where it rests on the thin rod and has little support. See photo 2.
I am going to replace the foam but without more support, it will be ripped also.
I'm not really asking for advice but thought others might be interested in how the seat is constructed.
Starting to think that modifying original seats might be the better way to go in the long run.
 Post subject: Re: Cobra seat internals
PostPosted: Mon Mar 25, 2019 11:27 am
Better also check the foam in the rest of the seat, mine turned to yellow powder and poured out the bottom.
I got my local Auto and marine trimmer to redo them both using foam blocks.
PostPosted: Mon Mar 25, 2019 12:03 pm
I remember your experiences with these. I am tempted to put a piece of plywood across the frame to support the new foam.
Haven't looked at the back part yet.
