It is currently Fri Jul 11, 2025 7:03 am
 Post subject: ID Plate sticker
PostPosted: Thu May 16, 2019 10:47 am
As you can see someone's painted over the plate and then has sand blasted or sandpapered the paint off again removing the black sticker from the plate. Does anyone know if the id plate sticker is available?
Thanks all
Sorry pic is upside-down (fixed by Mod)
 Post subject: Re: ID Plate sticker
PostPosted: Thu May 16, 2019 11:33 am
The black section was printed/painted onto the plate originally. It wasn't a sticker. So there's no easy way to recreate it, other than perhaps making a template and carefully spraying. Do you have an artistic talent or know someone who does?
Some would say leave it alone as "modified" ID plates can raise concerns about its authenticity. Many plates have the black areas scratched or removed so you are not alone.
PostPosted: Thu May 16, 2019 11:36 am
No there is no sticker available.
Mini shops sell reproduction blank ID plates however you would need to find someone with the correct font stamps or it will look like your trying to do something shonky.
I can't see anything wrong with yours. Its all part of the history. I would rather see a genuine ID plate without the black than a repro ID plate.
PostPosted: Thu May 16, 2019 2:09 pm
Thanks Winabby and goto, I will leaveit just as it is then when repaying the engine bay
PostPosted: Thu May 16, 2019 6:12 pm
Take it to a signwriter with another plate to copy from, they do an excellent job :D
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Fri May 17, 2019 8:01 am
I think I will leave it the way it is as it could look to be modified if there was shiny new paint on a 52 year old plate,
Thanks anyway
