https://ausmini.com/forums/
leyland mini wheel arch query
https://ausmini.com/forums/viewtopic.php?f=2&t=98305
Author:  Bennjamin [ Wed Feb 27, 2019 12:25 pm ]
Post subject:  leyland mini wheel arch query
Hey team
Can you offer suggestions for a couple of things - I am located in Sydney
I’m after Wheel arches to suit a clubman/leyland sedan with 10x6 minators ?
I am after non lipped style arches that cover the tyre tread with as little over hang as possible
Unsure of offset atm but standard track front and rear
Also - where locally to trial fit , and or purchase ?
Car is sitting in my garage and i’ll need to borrow , trial fit etc
I have purchased a set before cheaply overseas and had to sell at a loss as they just didn’t fit or suit
Thanks ben
Author:  Bill B [ Sat Mar 02, 2019 12:34 pm ]
Post subject:  Re: leyland mini wheel arch query
I am not sure what you are after exactly.
Have you looked at dealer sites such as:
https://minisport.com.au/flares-and-chr ... -mouldings
It is a bit difficult to 'try before you buy'. People with flares usually have them on their car already.
Have you been to car shows to see what is available for minis?
Sorry I can't be more help; I only have experience with the 'factory' style flares.
Author:  winabbey [ Sat Mar 02, 2019 1:43 pm ]
Ben - you probably already know but keep in mind front flares will be a different shape for round-nose and Clubman style. Rears are the same.
Author:  andrew9 [ Sat Mar 02, 2019 2:06 pm ]
If you're trying to figure out what size arches you need, the size seems to be based on the front arch at 12 o'clock.
So if you put straight edge over the tyre and measure to the bodywork directly above the front hub, you should get a good idea what size you need.
look out for what camber you're running, as this can change the amount it appears to protrude. Best to use a level to check really
Author:  Harley [ Sat Mar 02, 2019 5:44 pm ]
Can you take a wheel off and get the offset measurement?
Knowing that will make suggesting an arch easier.
Author:  Bennjamin [ Mon Mar 04, 2019 2:56 pm ]
All great replies
Thanks Ill look abit further into that site
Yes I am aware - its very limiting in choice and there is abit of mis info on the net what fits and what doesnt. What really is the difference (can one be made to fit the other and vice versa?)
Part of what brings me here is a link to a set I got awhile back , which ended up being too narrow and also not fitting the front at all. I really do want to get it right :)
Just done. thanks for the heads up !
Here are the basic details
wheels = minators 10x6 ET +6
Front
5cm to cover tyre from 12 o'clock
Rear
4cm to cover tyre from 12 o'clock
Hope that influences abit of input !
If anyone has some squarenose arches that suit , please speak up
Thanks again Ben
Author:  Harley [ Mon Mar 04, 2019 4:24 pm ]
Get yourself some monte-carlo arches. They are not lipped like you wanted, fit a clubman and are wide enough to cover your wheels. (6cm front, 5cm rear). They are made of plastic which cuts nicely if you want to trim them to narrow them up, and they dont need holes drilling into the guard except for the existing lip.
