65 Mk1 Cooper S RH tank https://ausmini.com/forums/viewtopic.php?f=2&t=98298 |
Author: | OnSafari [ Sun Feb 24, 2019 10:39 am ] |
Post subject: | 65 Mk1 Cooper S RH tank |
This Cooper is currently for sale at the Classic Throttle Shop. My question is the RH tank retaining strap correct? https://classicthrottleshop.com/wp-cont ... brg-19.jpg |
Author: | cooperess [ Sun Feb 24, 2019 11:01 am ] |
Post subject: | Re: 65 Mk1 Cooper S RH tank |
It should be on the right. |
Author: | winabbey [ Sun Feb 24, 2019 11:09 am ] |
Yes, the strap should be on the outside, like this. Attachment: RH Tank Position.jpg Which begs the question as to why it is like it is. If I were looking to buy I'd be measuring the position of the RH tank aperture to help confirm it is a genuine S body. It's a shame the description seems to be mostly a cut and paste from another car - "... the original spot welds for the flared guards, ...". |
Author: | OnSafari [ Sun Feb 24, 2019 12:19 pm ] |
That was my opinion as well. It raises some questions. Due diligence required! |
Author: | gtogreen1969 [ Sun Feb 24, 2019 12:30 pm ] |
OnSafari wrote: That was my opinion as well. It raises some questions. Due diligence required! There is a thread on car 522 here - viewtopic.php?t=96123 |
Author: | OnSafari [ Sun Feb 24, 2019 1:11 pm ] |
gtogreen1969 wrote: OnSafari wrote: That was my opinion as well. It raises some questions. Due diligence required! There is a thread on car 522 here - viewtopic.php?t=96123 Thanks, other fish in the ocean. |
Author: | crisonic [ Tue Feb 26, 2019 2:47 pm ] |
That's not the first time the strap has been fitted that way to a right hand tank. BMC Comps fitted it this way in 1965 to stop the tank sliding into the car and causing a short and subsequent fire due to the tank shorting out the battery terminals. In the event of a loose and the rear of the car hit a bank it could displace the tank.From memory it was Rauno Altonen's car.driving in his first Monte, that provided the impetus to fit the strap towards the inside of the car.It happened when he hit a rock bank causing a fire which totally destroyed the car. At the same time the battery was fitted with its terminals nearest to the spare wheel - furthest away from the tank. A piece of asbestos was fitted to the inner side of the tank as an additional safety measure.When studded tyres were used this asbestos was replaced by a plywood panel glued to the tank. Maybe your car has a rally history! |
Author: | deluxe67 [ Tue Feb 26, 2019 3:34 pm ] |
"BMC Comps fitted it this way in 1965 to stop the tank sliding into the car and causing a short and subsequent fire due to the tank shorting out the battery terminals." I also use a battery with terminals tyre side for this reason. |
