It is currently Sat Jul 12, 2025 8:29 pm
 Post subject: CS harsh ride 70
PostPosted: Sun Feb 17, 2019 4:23 pm
I got a blue slip for the CS on Friday All went well ,although he said it feels a bit harsh I fitted Polypropylene bushes in the engine stay should they be rubber, Also when I fitted the gearbox extension mount I had to really lever it into position, any ideas on harshness ?He also wanted to know why I moved the seats 22mm towards the centre of the car it was for clearance on retractor belts, he commented it gives a better driving position.
Allen
 Post subject: Re: CS harsh ride 70
PostPosted: Sun Feb 17, 2019 4:37 pm
They are harsh Allen Its the animal .Ive seen a mate rip a firewall where the clubby engine stay bolts on and had to be welded up and that was in all rubber days.I dont think urethane would be an issue with a "normal driver " haha
PostPosted: Sun Feb 17, 2019 6:29 pm
p7676 wrote:
I got a blue slip for the CS on Friday All went well ,although he said it feels a bit harsh Allen
His daily driver probably has a softer ride... :-)
https://www.carsguide.com.au/cars-for-s ... c14dc#pos0
PostPosted: Sun Feb 17, 2019 6:32 pm
The dreaded NVH was never one of the CS's good points!
PostPosted: Sun Feb 17, 2019 7:55 pm
I only use rubber bushes for the top engine steady - they don't move around much
I'm concerned about this bit - you shouldn't need to force anything to fit up - the top engine steady has a proper direction and does affect the position of the motor if not correct, so therefore where the remote ends up, and the remote bracket has its fore-aft adjustment.
I did mine last weekend - engine steady on, lift up the remote up - if the linkage doesn't engage I put a jack under it with a little bit of pressure and wiggle the gearstick, then it just slides up and bolts in.
PostPosted: Sat Feb 23, 2019 2:21 pm
changed one of the engine stabilizer bushes from pp to rubber big improvement
Users browsing this forum: Bing [Bot] and 97 guests
