Parking/starting Mini on a slope https://ausmini.com/forums/viewtopic.php?f=2&t=98251 |
Author: | ben23f [ Thu Feb 07, 2019 5:37 pm ] |
Post subject: | Parking/starting Mini on a slope |
Hi All, Just a quick question, I have a driveway that is about 45 degree slope and was wondering if the mini engine will be ok to startup on that angle? I had an old land rover once that wouldn't start on certain slopes as the fuel would drain back out of the carby. Thanks |
Author: | 9YaTaH [ Thu Feb 07, 2019 5:54 pm ] |
Post subject: | Re: Parking/starting Mini on a slope |
Ignition ON, Second Gear, get it rolling and pop the clutch,,,some tickling of the accelerator may help... |
Author: | ben23f [ Thu Feb 07, 2019 6:13 pm ] |
Sorry forgot to mention its facing uphill! |
Author: | gtogreen1969 [ Thu Feb 07, 2019 6:17 pm ] |
Uphill is fine as the pickup in the fuel tank goes through to the rear of the tank. If you park it downhill with less than 1/5th of a tank the pickup pipe could suck air. Attachment: Internal filter mesh Mini fuel tank.jpg The engine oil pick up should be ok. I would not keep it running for very long at that angle though. |
Author: | ben23f [ Thu Feb 07, 2019 6:43 pm ] |
Thanks. Its only a 10m driveway to get up then all good! |
Author: | simon k [ Thu Feb 07, 2019 9:12 pm ] |
just don't park it nose down, the fuel will drain out of the tank, through the carb and into the sump... bad news |
Author: | 1071 S [ Fri Feb 08, 2019 7:46 am ] |
ben23f wrote: Hi All, Just a quick question, I have a driveway that is about 45 degree slope and was wondering if the mini engine will be ok to startup on that angle? I had an old land rover once that wouldn't start on certain slopes as the fuel would drain back out of the carby. Thanks ..About 45 deg??? ...... perhaps a slight exaggeration ??? On that slope the one end of your mini is going to be about a meter and a hell higher than the other rend.. If you can stand there I'd be interested to hear how much oil is on the dipstick..... Cheers, Ian |
