Supercharged 1275 https://ausmini.com/forums/viewtopic.php?f=2&t=98217 |
Page 1 of 2 |
Author: | Chris.Williams [ Thu Jan 31, 2019 2:19 am ] |
Post subject: | Supercharged 1275 |
Hey all, Thought I’d put up a picture of my supercharged 1275 Clubman for all to see. Attachment: BDC0E8AD-0E07-41FF-98CE-2DC90EB2A052.jpeg
Author: | Toy444 [ Thu Jan 31, 2019 5:55 am ] |
Post subject: | Re: Supercharged 1275 |
Hi Chris, Nice set up! |
Author: | zulu_warrior1976 [ Thu Jan 31, 2019 7:12 am ] |
That’s cool! Did you fit all that yourself? Sent from my iPhone using Tapatalk |
Author: | Chris.Williams [ Thu Jan 31, 2019 7:26 am ] |
Toy444 wrote: Hi Chris, Nice set up! Thanks |
Author: | Chris.Williams [ Thu Jan 31, 2019 7:27 am ] |
zulu_warrior1976 wrote: That’s cool! Did you fit all that yourself? Sent from my iPhone using Tapatalk Thanks, yes rebuilt the motor and fitted the charger kit myself. It’s an m62 Eaton running a 40 dcoe. |
Author: | zulu_warrior1976 [ Thu Jan 31, 2019 7:30 am ] |
Mind if I ask where you got the kit? Is it easy to fit? |
Author: | simon k [ Thu Jan 31, 2019 9:37 am ] |
using a weber is a better idea than the silly uphill pipe for the SU implementation - and it has a throttle pump |
Author: | Pullstarter [ Thu Jan 31, 2019 10:29 am ] |
That's a very neat install! All seems to fit in very well. |
Author: | fffffred [ Thu Jan 31, 2019 11:22 am ] |
Now that's just showing off. ![]() Very nice and well thought out. Is the green stuff coolant? What's it plumbed to and from? Chris.Williams wrote: Hey all,
Thought I’d put up a picture of my supercharged 1275 Clubman for all to see. Attachment: BDC0E8AD-0E07-41FF-98CE-2DC90EB2A052.jpeg |
Author: | cooperess [ Thu Jan 31, 2019 11:28 am ] |
No oil cooler required? What is the compression ratio? |
Author: | Chris.Williams [ Thu Jan 31, 2019 4:44 pm ] |
zulu_warrior1976 wrote: Mind if I ask where you got the kit? Is it easy to fit? It’s a zmax kit from the Uk. Very simple to fit. |
Author: | Chris.Williams [ Thu Jan 31, 2019 4:46 pm ] |
Pullstarter wrote: That's a very neat install! All seems to fit in very well. Thanks very much, there is more room behind the charger then there ever was with twin su’s. Having the clubman she’ll also helps. |
Author: | Chris.Williams [ Thu Jan 31, 2019 4:52 pm ] |
fffffred wrote: Now that's just showing off. ![]() Very nice and well thought out. Is the green stuff coolant? What's it plumbed to and from? Chris.Williams wrote: Hey all, Thought I’d put up a picture of my supercharged 1275 Clubman for all to see. Attachment: BDC0E8AD-0E07-41FF-98CE-2DC90EB2A052.jpeg Yes green stuff is coolant, runs from a temperature controlled pump/reservoir through a radiator mounted behind my grill then through a plate between the charger and the manifold. Effectively a chargecooler |
Author: | Chris.Williams [ Thu Jan 31, 2019 4:57 pm ] |
cooperess wrote: No oil cooler required? What is the compression ratio? I have an oil cooler, not needed it yet. Compression is 8.7:1, I’m running 98 octane fuel and will more then likely add a meth/water injection kit. |
Author: | ausdino [ Sat Feb 02, 2019 10:46 pm ] |
Chris.Williams wrote: zulu_warrior1976 wrote: Mind if I ask where you got the kit? Is it easy to fit? It’s a zmax kit from the Uk. Very simple to fit. Not the Vmaxscart kit ? Looks the same. |
