Starter - 9 or 10 teeth pinion https://ausmini.com/forums/viewtopic.php?f=2&t=98204 |
Author: | Mick5961 [ Fri Jan 25, 2019 10:40 pm ] |
Post subject: | Starter - 9 or 10 teeth pinion |
Hi all, Just replaced my Lucas 9 tooth starter for a new 10 tooth. Some suggest its a non issue, others say the 10 tooth will eat the ring gear. Engine is a 1969 - 1100S block with a Mk3 Cooper head. Not sure on the ring gear teeth number though - 129/107? Cheers |
Author: | drmini in aust [ Sat Jan 26, 2019 9:00 am ] |
Post subject: | Re: Starter - 9 or 10 teeth pinion |
Both pinions work fine. But original was 9 tooth. |
Author: | Mick5961 [ Sat Jan 26, 2019 9:46 am ] |
Many thanks Doc, was worried there for a bit ![]() I wonder why some say the 10 tooth will eat the ring? ![]() Cheers Mick |
Author: | drmini in aust [ Sat Jan 26, 2019 10:15 am ] |
I have used a 10 tooth one for years. Re the 127T ring gear that is for the Rover pre-engaged starter which has finer teeth. |
Author: | Mick5961 [ Sat Jan 26, 2019 10:53 am ] |
Interesting, thanks for the feedback. Cheers ![]() Mick |
