1275 A+ thrust washers? https://ausmini.com/forums/viewtopic.php?f=2&t=98159 |
Author: | EST-071 [ Sun Jan 13, 2019 6:39 pm ] |
Post subject: | 1275 A+ thrust washers? |
Hi all, I'm building a 1275 A+. Just went to put the standard crank back in with std ACL thrust washers. They are way to tight, can only just turn crank and have next to no end float. Have I got the wrong washers? They are ACL 2T2204-STD KC number is BHM1293 STD They measure .092 thou so sound right. Any help would be appreciated. Cheers Pete |
Author: | drmini in aust [ Mon Jan 14, 2019 5:52 am ] |
Post subject: | Re: 1275 A+ thrust washers? |
Sand the back down on some wet and dry 180 paper. Measure with a micrometer. BTW 3 thou end float is too tight make clearance 5 thou + measured with a dial gauge. If you are going to rev it to 7000. Edit- I use .007" end float. |
Author: | EST-071 [ Mon Jan 14, 2019 10:53 am ] |
Drmini, Thank you for the help and advice. Greatly appreciated. Cheers Pete |
Author: | Ian_B [ Wed Jan 16, 2019 7:26 am ] |
Mine had to be surface ground on a machine with a magnetic attachment to get the 5 thou Material taken off steel side |
