It is currently Sun Jul 13, 2025 1:00 am
 Post subject: 1275 A+ thrust washers?
PostPosted: Sun Jan 13, 2019 6:39 pm
Hi all,
I'm building a 1275 A+. Just went to put the standard crank back in with std ACL thrust washers.
They are way to tight, can only just turn crank and have next to no end float.
Have I got the wrong washers? They are ACL 2T2204-STD KC number is BHM1293 STD
They measure .092 thou so sound right.
Any help would be appreciated.
Cheers Pete
PostPosted: Mon Jan 14, 2019 5:52 am
Sand the back down on some wet and dry 180 paper. Measure with a micrometer.
BTW 3 thou end float is too tight make clearance 5 thou + measured with a dial gauge. If you are going to rev it to 7000.
Edit- I use .007" end float.
Last edited by drmini in aust on Wed Jan 16, 2019 6:34 pm, edited 1 time in total.
PostPosted: Mon Jan 14, 2019 10:53 am
Drmini,
Thank you for the help and advice. Greatly appreciated.
Cheers Pete
PostPosted: Wed Jan 16, 2019 7:26 am
Mine had to be surface ground on a machine with a magnetic attachment to get the 5 thou
Material taken off steel side
