It is currently Sat Jul 12, 2025 11:40 pm
PostPosted: Thu Jan 10, 2019 9:01 pm
A question for the sparkies. If I swap old Mk1 two fuse box for the post 76 four fuse box (RTC440A) is it a simple bolt and plug in job as I want the other fuses for accessories like charger and air con.
67 Deluxe under going full resto
PostPosted: Fri Jan 11, 2019 10:10 am
yep, should be just swap it over, but I reckon you're better off going to a blade type fusebox. I have the standard fuse box and an extra blade type for all of the other sh*t I've put on the car
Jaycar have them cheap - something like this: https://www.jaycar.com.au/automotive-fu ... s/p/SZ2002
PostPosted: Fri Jan 11, 2019 3:25 pm
Blade type better but not original .My Clubby isnt original at all so Im doing headlight relays etc
PostPosted: Fri Jan 11, 2019 4:15 pm
This year or next year :lol:
PostPosted: Fri Jan 11, 2019 4:36 pm
Same year I put one on ya chin lol Soon as idiots back
PostPosted: Fri Jan 11, 2019 6:48 pm
I have a new harness for the deluxe so was looking for the easiest plug and play option that doesn’t bastardise the loom.
Will the jaycar loom plug in with the new harness and just have blades for fuses?
PostPosted: Sat Jan 12, 2019 3:47 pm
yes, the jaycar fuse box (loom?) will plug in to your new wiring loom, it has the same type of connectors. You should be able to simply replace the standard mini fuse box with it
PostPosted: Sat Jan 12, 2019 9:39 pm
Cool. I will get one
