https://ausmini.com/forums/
Any 1971 Cooper S Owners?
https://ausmini.com/forums/viewtopic.php?f=2&t=98096
Author:  winabbey [ Wed Dec 26, 2018 12:59 pm ]
Post subject:  Any 1971 Cooper S Owners?
The engineering drawing for the Cooper S (and Clubman GT) rear seat brace specifies a change to the way the RH fuel tank bracket was secured from 4 Feb 1971. If you have a Cooper S with a 2/71 or later build date on the ADR plate could you please check the method of securing, welded or bolted, and report back?
Author:  63lcn [ Thu Dec 27, 2018 3:01 pm ]
Post subject:  Re: Any 1971 Cooper S Owners?
Hi Winabby, I’ve not got a 71 S, but here is a pic of a 8/71 build GT. Spot welded bracket as per drawings.
Hope this helps.
Author:  winabbey [ Thu Dec 27, 2018 3:26 pm ]
Hope this helps.
Thanks for that. Confirms what has been discussed on Clubman GT Facebook groups that all GT's had the spot-welded bracket. The current initiative is to work out if and when it was implemented on a Cooper S.
Author:  excops [ Thu Dec 27, 2018 6:22 pm ]
Hi, My 71 S car no 2915,body no 2399 one of the last lot with anti burst handles was definitely bolted.
Author:  gtogreen1969 [ Fri Dec 28, 2018 12:00 pm ]
Cars 2853 and 2891 are bolted on.
Author:  winabbey [ Fri Dec 28, 2018 2:15 pm ]
So it appears the spot-welded bracket may not have appeared until Clubman GT production.
Author:  mini210 [ Fri Dec 28, 2018 4:00 pm ]
Could have been a cost cutting method to shift to spot welding on the Clubman GT??
Thats a fair bit saved spot welding, from installing the bolt brackets and nuts as done on the Cooper S's.
