https://ausmini.com/forums/
29D Distributor Cap
https://ausmini.com/forums/viewtopic.php?f=2&t=98080
Author:  Firefirey [ Thu Dec 20, 2018 3:48 am ]
Post subject:  29D Distributor Cap
Did Lucas Australia make the distributor cap for the MK 2 Cooper S?
I understand the original colour of the cap should be black.
What would be the part number inside the cap.
Any info would be great thanks
Author:  drmini in aust [ Thu Dec 20, 2018 1:57 pm ]
Post subject:  Re: 29D Distributor Cap
Yes I believe Lucas Australia did. They were used on other makes here also.
Bosch equivalent is a GL278.
Intermotor 46920.
Lucas 62410373, according to eBay seller in UK. This may also be the Oz number, I am not sure.
Author:  winabbey [ Thu Dec 20, 2018 7:02 pm ]
The 29D4 distributor came with a black Lucas Australia cap with the part number 62410456 embossed inside under the coil lead connector.
The only caps readily available now are the Bosch brown ones.
Author:  Firefirey [ Fri Dec 21, 2018 11:42 am ]
Thanks drmini in aust.
Have now seen a photo so know what to look for.
Author:  9YaTaH [ Fri Dec 21, 2018 12:58 pm ]
Weren't side-entry caps factory fitted at some stage :?: :|
Author:  drmini in aust [ Fri Dec 21, 2018 1:10 pm ]
Mk1 S had a 23D4 dizzy with side entry cap. Most? Mk2 S were 29D with top entry.
Author:  9YaTaH [ Fri Dec 21, 2018 4:38 pm ]
Thanks Doc...side entry were better for water protection with a boot...wonder what drove the change? (probably the parts bin overflowing with top entry...)
Author:  Scoop [ Fri Dec 21, 2018 9:58 pm ]
My guess was cost! 23d4 from england as opposed to locally built 29d. They did that with most stuff didn't they? 2 screw tail lights example, interiors, rocker and timing covers. What ever could be made here and not shipped over could be a saving.
Author:  9YaTaH [ Sat Dec 22, 2018 5:49 am ]
true...local content was mandated by the Gummint...
