HELP Front Hydrolastic bag Removal https://ausmini.com/forums/viewtopic.php?f=2&t=98023 |
Author: | asuth [ Mon Dec 03, 2018 5:33 pm ] |
Post subject: | HELP Front Hydrolastic bag Removal |
Hi All, Am trying to remove the front hydro bag to check it but cant get it out past the frame, everything is undone/removed, just cant get it out of it "hole" any trick to this? |
Author: | captainwaldopepper [ Mon Dec 03, 2018 5:49 pm ] |
Post subject: | Re: HELP Front Hydrolastic bag Removal |
Hi Asuth Have you removed the retainer plate that holds it steady, it's easy to miss. Cheers Dave |
Author: | simon k [ Mon Dec 03, 2018 7:25 pm ] |
is it loose? if it seems like it's rock solid, then rotate it, they have lock tabs holding them in tapping with a soft face hammer while rotating will shake it loose |
Author: | asuth [ Mon Dec 03, 2018 7:31 pm ] |
Yup got it all loose just couldbt get it out past the subframe. Looks like it has had an extra piece welded to the subframe for what reason i do not know. |
Author: | simon k [ Mon Dec 03, 2018 7:51 pm ] |
you sure it's welded? as Dave said, there's another little upside down L shaped bracket thats held on with 2 screws |
Author: | asuth [ Tue Dec 04, 2018 6:20 am ] |
Is this the bracket? On the in side? |
Author: | captainwaldopepper [ Tue Dec 04, 2018 6:32 am ] |
Yes, that's the one-should be held on with two screws Cheers |
Author: | asuth [ Tue Dec 04, 2018 6:39 am ] |
Cool. Ok I think the screws have been put in the wrong side? Otherwise how the hell do you get to them haha |
Author: | simon k [ Tue Dec 04, 2018 11:44 am ] |
asuth wrote: Cool. Ok I think the screws have been put in the wrong side? Otherwise how the hell do you get to them haha that's why we have stubby screwdrivers or screwdriver bits that go into a socket wrench adapter |
Author: | asuth [ Tue Dec 04, 2018 5:39 pm ] |
Got it! So simple ![]() Thanks guys |
