https://ausmini.com/forums/
rear quarter window seal 1970
https://ausmini.com/forums/viewtopic.php?f=2&t=98005
Author:  p7676 [ Tue Nov 27, 2018 6:43 pm ]
Post subject:  rear quarter window seal 1970
There are 2 types of rubber seals, the one that arrived today is different than the original, the original is like the door seal the other one is just rubber .Which is the best ? Bought from Karcraft
Allen. TY
Author:  Bill B [ Tue Nov 27, 2018 8:58 pm ]
Post subject:  Re: rear quarter window seal 1970
The rear quarter seals for a 1970 S is ALA5897. They are extruded rubber in one piece. This was originally fitted to my 1970 S and 1969 K but were unavailable for some time. If from Karcraft it will be described as 'original'. They sell both types.
The alternative is a later 2-piece seal with a plastic pinch-weld section glued to a sponge rubber seal PAM1019.
I have fitted both - they both work well but the one you have bought is correct for your car.
Author:  drmini in aust [ Wed Nov 28, 2018 5:54 am ]
Original works better over time than the sponge one.
Author:  cooperess [ Wed Nov 28, 2018 6:33 am ]
What about this part PAM1019SP!
http://www.classicmotoring.net.au/cmos/ ... vnahunqim6
Author:  Bill B [ Wed Nov 28, 2018 7:33 am ]
Just looked at Minispares UK who list PAM1019 (2-piece seal) as NLA and refer to EAM7724 - but that is for Mk3 on. I'm not certain but Mk3 might have a different sized rear quarter light.
What Allen received might be all that's available now. As drmini said, the 2-piece units had a habit of ungluing themselves over time.
Author:  drmini in aust [ Wed Nov 28, 2018 10:02 am ]
Mk3 UK windows are bigger.
Author:  winabbey [ Wed Nov 28, 2018 10:41 am ]
Does the profile of the seal you have look like this?
Author:  p7676 [ Wed Nov 28, 2018 12:14 pm ]
Yes Winnaby and they fit perfect fitted them this morning I usually have to fit some things twice
Allen
Author:  winabbey [ Wed Nov 28, 2018 12:28 pm ]
As a follow-up to this discussion here are the two seals sold by Minisport SA.
ALA5897
PAM1018
Author:  winabbey [ Wed Nov 28, 2018 1:07 pm ]
... and this is the original seal recently removed from my MK II S.
Author:  minimate [ Wed Dec 12, 2018 6:58 am ]
Where is the best place to put the two ends together, at the centre top of the window or bottom section?
Does anybody put a bead of silicone between the hinge and window frame?
Author:  Bill B [ Wed Dec 12, 2018 7:52 am ]
I put the join on the top edge under the gutter. Water does get under the seal and causes rust spots along the lower edge.
I think there was originally some butyl mastic type sealer under the hinge as it would help protect the screw holes from water.
