Gearbox Centre Bearing Shim https://ausmini.com/forums/viewtopic.php?f=2&t=97999 |
Author: | cooperess [ Mon Nov 26, 2018 1:49 pm ] |
Post subject: | Gearbox Centre Bearing Shim |
Attachment: Mini Gearbox Centre Bearing Shim 001.JPG How is the centre bearing checked to see which size shim is required?
Author: | drmini in aust [ Mon Nov 26, 2018 2:54 pm ] |
Post subject: | Re: Gearbox Centre Bearing Shim |
Assemble without shims and screws finger tight. Measure gap with feeler gauge. Fit shim a thou or 2 thinner than the gap. No shim = more preload against snap ring. Won't hurt bearing but may bend snap ring. Generally 1 shim fitted. Too many shims and bearing can spin in housing. |
