It is currently Sun Jul 13, 2025 2:36 am
PostPosted: Mon Nov 26, 2018 1:49 pm
How is the centre bearing checked to see which size shim is required?
PostPosted: Mon Nov 26, 2018 2:54 pm
Assemble without shims and screws finger tight. Measure gap with feeler gauge. Fit shim a thou or 2 thinner than the gap.
No shim = more preload against snap ring. Won't hurt bearing but may bend snap ring. Generally 1 shim fitted.
Too many shims and bearing can spin in housing.
