Rear seat belts 1970 mini https://ausmini.com/forums/viewtopic.php?f=2&t=97997 |
Author: | p7676 [ Sun Nov 25, 2018 7:26 pm ] |
Post subject: | Rear seat belts 1970 mini |
Hello All What are the best belts to fit to the rear, Inertia or the normal type ? Both types available. Allen |
Author: | simon k [ Sun Nov 25, 2018 7:53 pm ] |
Post subject: | Re: Rear seat belts 1970 mini |
I guess it's personal preference - fixed is more original |
Author: | 9YaTaH [ Mon Nov 26, 2018 8:11 am ] |
p7676 wrote: Hello All What are the best belts to fit to the rear, Inertia or the normal type ? Both types available. Allen The convenience of inertia reels might be outweighed in a sudden stop by the relatively small amount of room in a Mini. Inertia reels can allow some brief forward movement before locking, plus Seat belts are designed to "extend" when locked and restraining under high G (once extended (stretched), they have done their job, throw them away). Therefore, a firm fitting non-inertia belt has the advantage of immediately restraining in a confined space. |
Author: | cooperess [ Mon Nov 26, 2018 9:34 am ] |
Inertia reel belts are not used in racing. |
Author: | michaelb [ Thu Nov 29, 2018 12:54 pm ] |
I have a similar question about rear seat belts in an early mini. Does any one have tips on where to get them fitted in Sydney and any idea as to what type of additional body work bracing or plates are required? Especially for the rear parcel shelf? Looking at the plates in the later clubmans it doesn’t appear too much extra bracing was required? |
Author: | drmini in aust [ Thu Nov 29, 2018 2:12 pm ] |
Little's in Blacktown. On Sunnyholt Rd. There is another place on Powers Rd opposite O'Brien Glass, can't recall the name. http://roadsafety.transport.nsw.gov.au/ ... tcode=2147 |
Author: | winabbey [ Thu Nov 29, 2018 2:13 pm ] |
This has been discussed many times without an agreed, simple answer. If you do a search on "rear seat belts" you'll find over 300 hits, although many are hits on the same thread. Suggest you have a look at what's been said already. |
Author: | michaelb [ Thu Nov 29, 2018 2:44 pm ] |
Thanks guys I looked in “how to” but couldn’t find any thing Maybe after I sort it out a new How to can be added? It’s been a while since the last one was added ![]() |
Author: | peterb [ Sat Dec 01, 2018 7:47 am ] |
It's simple really, go to your local engineer and ask. Take some pictures of later mini belt mounts with you to show him. |
Author: | 9YaTaH [ Sat Dec 01, 2018 1:37 pm ] |
Search found 22 matches Search term used: rear seat belts Search Topic Title only |
Author: | michaelb [ Sat Dec 22, 2018 2:56 pm ] |
An update on my progress. I spoke with Mobility Solutions at Hornsby and they can assist with fitting rear seat belts and certification. Quoted me $440 per seat belt supplied and fitted plus $440 for certification. I have also spoken with a seat belt and baby seat fitting company at Brookvale who I have set up a visit with the car after Christmas. Said they could be a little cheaper for belts but Mobility Solutions will still need to provide certification. General concensous from a few mini owners who have rear seat belts is they have fitted them and not worried about certification. I guess it’s fine until they are needed? Then a mini is probably not the best car to have an accident in. I did fit rear seat belts in my Cooper S in the 70,s before certification was such a big thing. |
Author: | AWOODY [ Sat Dec 22, 2018 3:54 pm ] |
See pm |
