It is currently Sun Jul 13, 2025 6:02 am
PostPosted: Tue Nov 20, 2018 2:27 pm
I'm fitting an aftermarket heater into the mini to get through rego and need to get the heater hoses into the cab neatly, there is one hole available in the usual spot but the other is covered by the top engine steady, is there another suitable place people normally use?
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
PostPosted: Tue Nov 20, 2018 3:14 pm
I have that engine steady fitted and ran both heater hoses through there - there is space for the second one to fit behind/under the bracket.
Sent from my SM-G900I using Tapatalk
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Tue Nov 20, 2018 3:21 pm
There are a couple of photos showing the routing here:
https://classicregister.com/id-guides/h ... ni-1275-ls
