Odometer repair https://ausmini.com/forums/viewtopic.php?f=2&t=97954 |
Author: | Tomtax [ Thu Nov 15, 2018 5:41 pm ] |
Post subject: | Odometer repair |
Hi All My Odometer has stopped working. I was going to take it to an instrument repair shop however that are quite busy so I may be without a speedo for some time. Is it a big deal to fix? Thanks in advance |
Author: | 9YaTaH [ Thu Nov 15, 2018 7:14 pm ] |
Post subject: | Re: Odometer repair |
Tomtax wrote: Hi All My Odometer has stopped working. I was going to take it to an instrument repair shop however that are quite busy so I may be without a speedo for some time. Is it a big deal to fix? Thanks in advance Not a big deal to fix if you have the right parts or know what you are doing...I assume you still have a speed indication? (the Odometer just records miles/kilometres travelled) If your speedo is not working, check to see if the cable drive is turning at the speedo "head"... |
Author: | Lcmini [ Thu Nov 15, 2018 8:36 pm ] |
Hi Speedo is fine just the odometer has stopped |
Author: | 9YaTaH [ Fri Nov 16, 2018 6:54 am ] |
Lcmini wrote: Hi Speedo is fine just the odometer has stopped Could be something simple like the speed nut holding the pawl on could have fallen off, the placky gears are worn out or it has jammed due to lack of lube on the pawl eccentric shaft... |
Author: | Timbo [ Fri Nov 16, 2018 11:05 am ] |
Its very common for the odometer to wear out. They usually fail when they have to turn over a bunch of 9s. The pawl that pulls the gears round usually wears away. Depending on the age of the speedo the pawls are usually either brass or plastic, both of which are soft and eventually give up. Its probably possible to build up the brass ones and file them back into shape, but the plastic ones would be hard to do much with. Tim |
Author: | drmini in aust [ Fri Nov 16, 2018 8:38 pm ] |
Could also be the pawl spring broken. I fixed my S speedo by robbing a spring from a Mini deluxe? one. |
