It is currently Sun Jul 13, 2025 5:58 am
PostPosted: Thu Nov 15, 2018 5:39 pm
Does anyone know if there’s a manual available for the ac fitted to the rover minis?
I can’t work mine out!
The green circled knob seems to just turn a quarter turn, no clicks, but do nothing obvious
The yellow circled Fan knob seems to have three or four positions it clicks into but nothing happens until the 4th when AC blasts
I think the blue circled pull knob is for the normal hot air Intake from the engine. Unclear if I pull for hot air or push it in?! Feels like hot air coming in when the knob is pushed in...
Any thoughts would be great thank you
PostPosted: Thu Nov 15, 2018 5:49 pm
Here is a 1992-1996 manual, it may be of some assistance.
https://www.miniscene-unterfranken.de/w ... _92-96.pdf
On other cars I have seen the fan resistors stuff up causing loss of the lower fan speeds.
PostPosted: Thu Nov 15, 2018 7:59 pm
Thanks for the link
Handy for my library but it’s a repair manual so much more technical than my stupid questions require!
I’ll see if I can find some fan resistor I do though, thanks for the suggestion
PostPosted: Fri Nov 16, 2018 10:01 am
Sounds like the fan resistor has gone to lunch.
PostPosted: Fri Nov 16, 2018 10:09 am
That one is pull for heat. The heater and aircon units are completely separate systems?
PostPosted: Fri Nov 16, 2018 10:35 am
This drivers handbook doesn't include air con, but chances are there's one somewhere on the net. I found this Googling Rover Mini drivers handbook so suggest you do some searching.
https://www.uscars.biz/uscars/mini-docu ... 01795e.pdf
PostPosted: Fri Nov 16, 2018 12:08 pm
If you are a Facebook user this group should be able to assist.
https://www.facebook.com/groups/rovermini
PostPosted: Fri Nov 16, 2018 7:37 pm
Thanks! Great tips, I’ll try the Facebook and didn’t find any Ac stuff in the handbook but did find some other useful information :)
PostPosted: Tue Nov 20, 2018 9:18 pm
No luck with any handbooks or Facebook but I joined the UK mini forum (blasphemy!) and there is a rover sport section there which is quite active.
The consensus is the green knob is the thermostat / temperature and the fan blower switch is the yellow but the resistor pack is gone.
So the next step, if I can be bothered, is finding the resistor pack part, and where the hell it goes in my mini!!
PostPosted: Wed Nov 21, 2018 7:26 am
Had a quick squiz of what I have from the same source...not mush is the answer :-(
[Edit: Hmmmmm...The extension pdf is not allowed]
PostPosted: Wed Nov 21, 2018 7:43 am
The resistor pack should be in the ducting near the blower. They mount them in the airflow to cool the resistors.
PostPosted: Wed Nov 21, 2018 12:21 pm
Ah ok... somewhere in the impossible-to-remove plastic surrounds! Interesting how little this is covered online, can't find any info about it at all.
PostPosted: Wed Nov 21, 2018 12:23 pm
Sorry i can't be of more help but i have never played with the Rover Minis. Good luck.
PostPosted: Wed Nov 21, 2018 12:31 pm
All good! I enjoy working things out, except when I break stuff and make it worse
PostPosted: Wed Nov 21, 2018 5:46 pm
This is the resistor pack you are looking for, it is in the bottom of the evaporator, secured by 1 screw.
Steve
