Metallic rattle on left hand side under acc at low speeds https://ausmini.com/forums/viewtopic.php?f=2&t=97950 |
Author: | brett [ Wed Nov 14, 2018 11:11 pm ] |
Post subject: | Metallic rattle on left hand side under acc at low speeds |
Hi guys this has been annoying me. When I get into it on1st and 2nd gear there is an annoying loud metallic rattle on the left hand side. It's not mechanical I think as soon as I change from 1st to 2nd it's gone until I get the rpms back up highish. Then goes when I change into 3rd. ( I dont get the revs that high in 3,4,5. Has anyone experienced this. I can't seem to find anything loose except the grill that's the only thing I can think off. But it doesnt sound frilly. But plan on putting bigger screws in... |
Author: | gtogreen1969 [ Wed Nov 14, 2018 11:51 pm ] |
Post subject: | Re: Metallic rattle on left hand side under acc at low speed |
I had a slight rattle from my grill at idle. I put some plastic/rubber washers behind the screws and the rattle has gone. Attachment: Grill screws.jpg
Author: | Wakka [ Thu Nov 15, 2018 6:19 am ] |
We chased a similar rattle for ages. Eventually found the radiator touching the shroud, the number plate a little wobbly and the front bumper touching the body. Also, a tune up made for smoother running and hence less vibration. Extractors and and RC40 drowns out any rattles! |
Author: | drmini in aust [ Thu Nov 15, 2018 7:11 am ] |
I have had similar rattles when the radiator surround breaks the tiny rivets or spot welds at top tank. I fixed them with short M3 screws & nuts. Edit- typo. |
Author: | brett [ Thu Nov 15, 2018 6:20 pm ] |
Thanks guys will have a play over the weekend! |
