https://ausmini.com/forums/
Head gasket issue
https://ausmini.com/forums/viewtopic.php?f=2&t=97933
Author:  Ian_B [ Sat Nov 10, 2018 1:39 pm ]
Post subject:  Head gasket issue
Pistons come right to top of bore BK450 gasket overhangs bore a little Middle cylinders 73mm bore not offset.
Do I run with it till it fails if it does or go with a cometic gasket that doesnt use fire rings.
Finish on head and block is very smooth but not measured.
So close and this issue raises its head
Author:  Ian_B [ Sat Nov 10, 2018 7:04 pm ]
Post subject:  Re: Head gasket issue
Keith Calver knows this issue. Has a good article on it about using a head gasket as a guide for boring.
Not many do here it seems
Author:  drmini in aust [ Sat Nov 10, 2018 9:16 pm ]
Bore of a BK450 gasket is 73.5mm I just measured a couple.
So even if not offset bored, there's probably not much in it. My 1360 motor is also 73mm bore, not offset and never had a BK450 gasket failure. Has been to 8000 a few times. It does have .010" deck height though.
Author:  ken@miniauto [ Sat Nov 10, 2018 9:27 pm ]
Cometic C4148 gaskets are 74mm and are available from .030" thick . Not cheap but do the job
Author:  Ian_B [ Sun Nov 11, 2018 3:04 pm ]
Thanks guys Will go cometic .Its bloody hard to machine the pistons to get deck clearance once they are pressed on the rods lol.
Author:  simon k [ Mon Nov 12, 2018 9:12 pm ]
nahhhh mate, just put them at TDC and run a rasp over the lot
Author:  Ian_B [ Fri Nov 23, 2018 7:57 pm ]
Thanks guys All redone today with a 74mm cometic .027 that I didnt know existed Will be all fine now as my local machinist insisted on decking the block and head to a mirror finish.
Author:  peterb [ Sun Nov 25, 2018 8:13 am ]
Isn't a belt sander a better option?
Author:  simon k [ Sun Nov 25, 2018 12:37 pm ]
fwoar, that's a sh*t hot idea - I can hold the sander in one hand and my beer in the other
