https://ausmini.com/forums/
Forged Rockers
https://ausmini.com/forums/viewtopic.php?f=2&t=97923
Author:  cooperess [ Tue Nov 06, 2018 4:06 pm ]
Post subject:  Forged Rockers
What is the purpose of the arrowed hole?
Author:  drmini in aust [ Tue Nov 06, 2018 9:36 pm ]
Post subject:  Re: Forged Rockers
To spray oil around the valve gear. To lube the rocker ends.
But not needed, it's pretty foggy with oil up there anyway. Later rocker designs don't have them.
Author:  cooperess [ Tue Nov 06, 2018 9:41 pm ]
Thanks drmini in aust.
Where does the oil come from? The hole does not go through the bush.
Author:  drmini in aust [ Wed Nov 07, 2018 7:29 am ]
it is supposed to. Someone has changed the bushes. And not drilled through them.
Author:  cooperess [ Wed Nov 07, 2018 8:02 am ]
Offset bushes have been fitted, so there are 2 hole holes, a large one for the adjust and small one for the oil mist. Am I correct?
Author:  drmini in aust [ Wed Nov 07, 2018 12:18 pm ]
Yes. I have done a few sets with offset bushes. Don't believe anybody that says offset bushes will give S rockers a 1.5:1 ratio.
I made .044" offset bushes (is more than the ones being sold) and only just got to 1.3:1 with pressed steel (1.2:1) 998 rockers. And stock forged S rockers are even worse at 1.16:1 ratio.
These lift ratios calculated on a 1275 head with Graham Russell RE13 cam (.290" lobe lift).
If you do want 1.5:1, buy new rockers. ;)
