It is currently Sun Jul 13, 2025 9:16 am
 Post subject: Forged Rockers
PostPosted: Tue Nov 06, 2018 4:06 pm
What is the purpose of the arrowed hole?
 Post subject: Re: Forged Rockers
PostPosted: Tue Nov 06, 2018 9:36 pm
To spray oil around the valve gear. To lube the rocker ends.
But not needed, it's pretty foggy with oil up there anyway. Later rocker designs don't have them.
PostPosted: Tue Nov 06, 2018 9:41 pm
Thanks drmini in aust.
Where does the oil come from? The hole does not go through the bush.
PostPosted: Wed Nov 07, 2018 7:29 am
it is supposed to. Someone has changed the bushes. And not drilled through them.
PostPosted: Wed Nov 07, 2018 8:02 am
Offset bushes have been fitted, so there are 2 hole holes, a large one for the adjust and small one for the oil mist. Am I correct?
PostPosted: Wed Nov 07, 2018 12:18 pm
Yes. I have done a few sets with offset bushes. Don't believe anybody that says offset bushes will give S rockers a 1.5:1 ratio.
I made .044" offset bushes (is more than the ones being sold) and only just got to 1.3:1 with pressed steel (1.2:1) 998 rockers. And stock forged S rockers are even worse at 1.16:1 ratio.
These lift ratios calculated on a 1275 head with Graham Russell RE13 cam (.290" lobe lift).
If you do want 1.5:1, buy new rockers. ;)
Users browsing this forum: Bing [Bot] and 84 guests
