Removing steering lock from column https://ausmini.com/forums/viewtopic.php?f=2&t=97886 |
Author: | AWOODY [ Thu Oct 25, 2018 4:14 pm ] |
Post subject: | Removing steering lock from column |
Any tips on removing the ingnition/steering lock from the steering column. |
Author: | Morris 1100 [ Thu Oct 25, 2018 5:52 pm ] |
Post subject: | Re: Removing steering lock from column |
A) Cut a slot in the screw heads with a hacksaw or a Dremmel and use a screwdriver. B) Use a centre punch to undo the screws. |
Author: | simon k [ Fri Oct 26, 2018 9:21 am ] |
Morris 1100 wrote: A) Cut a slot in the screw heads with a hacksaw or a Dremmel and use a screwdriver. B) Use a centre punch to undo the screws. C) drill a hole in them and use an easyout - the ONLY time I recommend using an easyout... |
Author: | drmini in aust [ Sun Oct 28, 2018 8:21 am ] |
If removing permanently (as we did for our 71 Clubby getting centre speedo) use Mr Anglegrinder. ![]() |
Author: | Convertible Mini [ Sun Nov 04, 2018 7:50 am ] |
Wasn't the actual steering Column lock one of the ADRs of 71? So removing steering lock permanently makes the vehicle non compliant ! Yes ? No ? |
Author: | Morris 1100 [ Sun Nov 04, 2018 10:41 am ] |
1972. |
Author: | drmini in aust [ Sun Nov 04, 2018 9:13 pm ] |
Some 71 Clubbies still had the centre speedo binnacle and switchgear. No steering lock. |
Author: | 9YaTaH [ Mon Nov 05, 2018 11:37 am ] |
drmini in aust wrote: Some 71 Clubbies still had the centre speedo binnacle and switchgear. No steering lock. So it could depend on what ADRs this car has stamped whether it is legal or no ![]() |
Author: | drmini in aust [ Mon Nov 05, 2018 12:08 pm ] |
9YaTaH wrote: drmini in aust wrote: Some 71 Clubbies still had the centre speedo binnacle and switchgear. No steering lock. So it could depend on what ADRs this car has stamped whether it is legal or no ![]() ADR plate is optional. Not needed for NSW registration if missing... ![]() Who would check this anyway. It's a club car. |
Author: | AWOODY [ Mon Nov 05, 2018 3:24 pm ] |
Thanks guys there is no ADR plate for this car 1970 registration. |
