https://ausmini.com/forums/
I have 3 skimmed 12G295 heads. Which one should I use?
https://ausmini.com/forums/viewtopic.php?f=2&t=97883
Author:  astimini [ Wed Oct 24, 2018 8:25 pm ]
Post subject:  I have 3 skimmed 12G295 heads. Which one should I use?
I have 3 12G295 cylinder heads. I want to use one on my 1990 998 mini.
They all seem to be in good condition but have all been slightly skimmed.
Head 1 skimmed from 2.75 to 2.67.
Head 2 skimmed from 2.75 to 2.63.
Head 3 skimmed from 2.75 to 2.59.
Considering that 80 thou (2mm) is recommended, I would of thought head 1 would be the correct one to use on my 988?
Does this seem to be correct?
Thanks
Author:  drmini in aust [ Wed Oct 24, 2018 9:26 pm ]
Post subject:  Re: I have 3 skimmed 12G295 heads. Which one should I use?
Use the thickest one.
The concern with all these old small bore heads is deck thickness, they nearly all have corrosion inside after 50+ years and this thins them down.
If too thin they blow gaskets.
Author:  astimini [ Fri Oct 26, 2018 12:45 am ]
I totally agree. The 3rd head looks alarmingly thin already.
