Sliding Window Conversion https://ausmini.com/forums/viewtopic.php?f=2&t=97845 |
Author: | 2lateagain [ Sun Oct 14, 2018 5:41 am ] |
Post subject: | Sliding Window Conversion |
Saw this on an English site. http://mk1-forum.net/viewtopic.php?f=5& ... 5ad5746c32 |
Author: | greyghost [ Sun Oct 14, 2018 2:30 pm ] |
Post subject: | Re: Sliding Window Conversion |
not really relevant here, as those kits are for the Mk3 onwards and in reality the Oz windup windows are better for air-flow through the cabin than any sliding window, especially at low speeds |
Author: | Phil 850 [ Sun Oct 14, 2018 9:12 pm ] |
greyghost wrote: not really relevant here, as those kits are for the Mk3 onwards and in reality the Oz windup windows are better for air-flow through the cabin than any sliding window, especially at low speeds I have often heard this comment about poor airflow in a sliding window mini. However, I have one and am surprised by how good the airflow really is. Depending on how much you open the front or rear half of the door windows and also the rear windows you can have a howling gale through the car. I don't know how much better it could possibly be ![]() |
Author: | 1071 S [ Mon Oct 15, 2018 7:48 am ] |
+1 Cheers, Ian |
Author: | 9YaTaH [ Mon Oct 15, 2018 8:12 am ] |
How do they go at the Toll Booths, Carwash or Burger Joint drivethu's ![]() ![]() |
Author: | greyghost [ Mon Oct 15, 2018 2:48 pm ] |
the airflow is fine if your moving, but when you are in traffic crawling along its horrid |
Author: | Phil 850 [ Mon Oct 15, 2018 8:13 pm ] |
9YaTaH wrote: How do they go at the Toll Booths, Carwash or Burger Joint drivethu's ![]() ![]() There are no toll booths any more, keep them closed in the carwash ![]() ![]() |
Author: | 9YaTaH [ Tue Oct 16, 2018 6:16 am ] |
Phil 850 wrote: 9YaTaH wrote: How do they go at the Toll Booths, Carwash or Burger Joint drivethu's ![]() ![]() There are no toll booths any more, keep them closed in the carwash ![]() ![]() Sure...OK, add car park boom gates where you take a ticket ![]() |
Author: | MuckUte [ Tue Oct 16, 2018 6:41 pm ] |
With the drive thru I find it's not so much the sliding windows but the fact the roof of the mini is a similar height to the bottom of the drive thru window |
Author: | Phil 850 [ Tue Oct 16, 2018 8:37 pm ] |
MuckUte wrote: With the drive thru I find it's not so much the sliding windows but the fact the roof of the mini is a similar height to the bottom of the drive thru window Was it the mini Sunshine that had a sunroof ?. They could just drop your order down to you ![]() |
Author: | 9YaTaH [ Fri Oct 19, 2018 7:04 am ] |
Phil 850 wrote: MuckUte wrote: With the drive thru I find it's not so much the sliding windows but the fact the roof of the mini is a similar height to the bottom of the drive thru window Was it the mini Sunshine that had a sunroof ?. They could just drop your order down to you ![]() Yes they did...as did many other Mini's fitted with after-market sunroofs...the idea of having your order dropped down to you is a little scary tho ![]() |
